1250 gs spot lights
Not open for further replies.
MRDDD
Everywhere
Having a r1250 gs 2019 . I have fitted from bmw the genuine spots-fog-riding lights on the light bar but i am looking for SPOT lights only that can be connected to the high beam only . Ive contacted Denali but they want to sell me a full complete kit with all the canbus leads brackets etc
Do i need to have this or is there a spot only light that i can tap into my high beam with out affecting the bikes electrics
Thank
Please avoid the comments that Denali are brilliant bright lights that you wont find better although expensive i know this i just want a spot light
Cant help , just thought I would say the the BMW ones look way better than the square denali ones , there must be a way that you can fiddle with the switch using a by pass or something , come on there must be an auto electrican on here to help.
My mate did it but I think he used some switch from his old lights ( not sure what lights ) but he did it , I cant wire jack.
Ian, the OEM spots give sufficient light, you just need a method to get them switch when you want them, ie on high beam. I believe the Denali CanSmart or similar boxes enable this. Will just need a minor re-wire once you have bought the controller you most like the look of. Are you really going to ride that much at night ;) especially in Wales (if this trip happens at all...........)
