yellowgs
anyone any ideas how to turn the 1200gs power socket in to a normal size one?
Just explain why you want to change it for a standard one ?
Eggsy
Be careful some of those new power adaptors for GPS etc are actually voltage reduction
Check out some of the Marine 12volt sockets on E bay If you're looking for 12 volt in a normal cigarette lighter sized power outlet
many thanks
I rigged up a 12V Cigarette Lighter type socket on my left handlebar. Used an old Maplins 12V extension lead I had lying around. Wired up directly to the battery via an inline fuse. Also made a BMW sized one for the right handlebar. Placed a BMW Socket (courtesy of Jaythro) inside an old 12Gauge shotgun Cartridge, before mounting onto handlebarand wired up as above.
anyone any ideas how to turn the 1200gs power socket in to a normal size one?![]()
do BMW sell an adaptor to go from OEM size thats under the seat to 'standard' car type ciggy?
Not that I know of.
What you can sometimes find, usually in Continental motorway service shops, are assorted gizmo's suitable to plug into the Din sockets, as they are used on some trucks.
The home made conversions are easy enough to do and you can't break anything (unless you try really hard)![]()
Nippy Normans sell one, it's only a few quid and works well.
Excellent, i'll take a look now![]()
This looks like it will do just the job
http://www.nippynormans.com/CONVERTER-CAR-PLUG-TO-BMW-PLUG/productinfo/BAS-BA14/
Thanks, its really annoying its not standard, i like its position, and i don't even have a tank bag yet, but when i do i want to run a lead from there to the bag, and power my iPaq. Got a power adator for it, which i use in the car as well but its standard size.
Might have to run a second lead, i like the handle bar position for plug![]()
