Heisenberg
Ok, here goes....
2007 GSA, fails to show any lights - no ignition. Must be the ignition switch I think....disconnect negative lead at battery, remove securing shroud from ignition switch, separate both connectors, spray copius WD40 in male/female connectors. Spray further WD40 down the ignition barrel.
Turn key about 100 times (slight embellishment) and away we go, we have a full display and its ready to go. Hooray!
However, press the start button and "CLICK". Hard to tell if it is coming from starter or not (solenoid should be fine and throwing in). Then I get an error display on dash - the small engine shaped error???? Eventually get an EWS error, but only once.
Now, full display every time, but just the dreaded "CLICK" every time to go with it. Any ideas guys?
PS: Already over one hour late for work, and it's raining!
Thanks in advance
Thanks in advance
