kirky1298
Ok , I gave the bike a service last night . Rocker end float , Valve clearences , TPS set up , Oil & Filter & new plugs .
I fired it up last night and it was running sweet as a nut .Ran it for about 10 mins .
Just went out to the garage to give it run and it won't bloody start
checked the kill switch was off . DAMHIK
checked the fuses
re-checked TPS
sprayed the sidestand switch with wd40
checked it was in neutral .
It's making all the right noises , just wont start . pulled the plug leads and it doesn't appear to have a spark .
SIDESTAND SWITCH ????
HALL SENSOR ?????
ANY OTHER SUGGESTIONS
checked the fuses
re-checked TPS
HALL SENSOR ?????
