Captain GSA
Tosser Extraordinaire
Captain! I'll take both. I already have a brilliant 1200, so a second lighter one will do for now.....![]()
Sold
I'll virtually send them both to you now, you should virtually get them within a second or two...
The Tenere pic could be closer than you think. Yamaha are launching a 1200 version at the end of the year apparently, and maybe BMW are thinking of that by first introducing a 800/650 range, which could be complemented by a 1000 or 1200 long distance version. A 1200 Tenere would probably be much lighter than a current 1200GS and maybe BMW are worried about losing sales.
I'm not falling into any trap. I bought the outgoing 07 model for a discountGS Monkey, why fall into the trap that BMW want you in... 08 is only just here....
Hardly a new boxer engine. They've tweaked the ignition slightly, but its substantally the same drive train. Its a cheap end-of-model upgrade, not mid-life. The 1200GS has had its 5yrs.......... time for a new modelThe 1200GSA has been fitted with a new type of boxer engine coming from the R1200R. It's pretty much a mid-life upgrade.
If they watercool the boxer (must be possible as per the CX500?) the stylist will struggle not to make it the uglyiest engine from uglyville.
Shep
I reckon I'm on to something here. Does anyone have a phone number or BMW R&D? I'm sure it would be possible to lose two of the four cylinders (maybe even on oposite sides for symmetry's sake) Sorted.
Hardly a new boxer engine. They've tweaked the ignition slightly, but its substantally the same drive train. Its a cheap end-of-model upgrade, not mid-life. The 1200GS has had its 5yrs.......... time for a new modelThe competition are moving in and hence BMW will keep developing to keep ahead.
Hopefully a new generation boxer will evolve............
1200 GS engine is 101 x 73 mm bore / stroke
800 GS engine is 82 x 75.6 mm
So not that much extra piston size for 1200, if they wanted to convert the 800 engine
Wonder if they'll go the 1 ltr route then up it to 1100 then 1150 then 1200![]()
Ok then, a motor derived from the 800, shared by the F series generally, suggesting perhaps that BMW have plans to develop it further for future models. The fairly limited tank range on the F800GS might somehow be increased to create a GSA version, perhaps if the engine is stepped up to 900 or 1000cc.
R1100GS 1994 to 1999 5yrs
R1150GS 1999 to 2004 5yrs
R1200GS 2004 to 2009?
Based on recent oilhead production development, you'd think that the current facelift is to tide the models over until a major development in 2009. Should be interesting to see what they come up with next.
Just hope the boxer is still up to the job with the new emissions / noise regs.
Tell us what you know then - you can't just keep it to yourselfYou are all on the right lines......watch this space for the Vtwin watercooled GS and later the Adventure....
It will happen....sooner rather than later....![]()
I think they'll loose more customers than they think if they don't (no big sticky out things to warm your slippers on)Hope they can keep the boxer going ....
Tell us what you know then - you can't just keep it to yourself![]()
Boxer engines probably got their name because the pistons of the motor, when observed from the top, resemble the fists of a boxer pummeling his opponent.
One benefit of using a boxer engine versus a V-engine is that the design provides good balance because each piston's momentum is counterbalanced by the corresponding piston movement of the opposite side. Boxers are one of only four layouts that have a natural dynamic balance; the others being the straight-6, the V12 and the ****el engine.
These engines can run very smoothly and free of vibrations with a four-stroke cycle and do not require a balance shaft or counterweights on the crankshaft to balance the weight of the reciprocating parts, which are required in other engine configurations
.........not a lot of truth in the rumours so far then!
