Is the oil filler really on the right hand rocker cover?
If the new DOHC engine is the same as the HP2S, then Yes
So one pours oil into the right-hand-side, then run around to the left - crouch down, wait and check the level, then run back round to the right-hand-side - pour in some more oil, then run around to the left............ repeat until correct oil level is acheived![]()
is an easy way to overfil
Thanks for confirming that.
Your way, if seriousis an easy way to overfil
So why would a GS rider bother with a 2010 bike with a more complex engine, that needs high octane fuel and costs more to buy and maintain - just to gain 5 hp that a GS doesn't really need
It's my fault...they always change things after I buy one..![]()
Looks like if you want the extra 5hp you will need 98.
From bmw's own spec sheet,
Fuel type, Unleaded super and premium, octane number 95-98 (RON) (knock sensor; rated output at 98 RON); optional extra 91 (RON) available
The 2010 GS does not use shims.
And if you get the 91 octane option, the engine actually produces 5 HP LESS (100 HP) than the '09 models.
