Quendi
the wiring harness completely burned out taking the alternator and possibly ABS pump with it.
Claim on the insurance hopefully?
Quendi
(home made model, ofcourse)
I still have pleasure in e-mailing the previous registered owner & sending him photos of my travels.
Nice![]()
Andres
Hi,
Interesting to hear about peoples experiences...I've just bought an 08 plate 1200GS after riding a Honda Blackbird for just over 5 years. Done 63K miles on the Blackbird even though its a Honda it has not been without problems. The regulator rectifier/alternator has had to be replaced 3 times and the cam chain tensioner has gone twice. The bike has left me stranded twice and had to be recovered by the RAC.
final drive is totally knackered at 19,000 miles,
This all sounds pretty BAD.
I had a valve jam which then ment the piston came accross and smashed everything to bits.
The bike was 3 1/2 years old and had done less than 10,000 miles cost to repair £1600 parts and labour. I eventully got 50/50 on parts but this really should not happen with such a low milage should it ?.
Of course they said its 3 1/2 years old but to me it shouldnt matter if its 12 years old when it had only done 10,000 miles
The manager of the dealership tried to say this had never happened to any bmw before but yet other people that worked there know of two other incidents, why cant they just be honest !
I ain't finished yet! Get this:
While researching the problem I came across a lot of stuff about these bikes stripping the splines on the gearbox input shaft and/or the clutch centre. Apparently you are supposed to take the gearbox off and lube the splines every 20,000 miles! I was staggered by this, I've never heard the like, but some guys in the US have even made special tools to try and lube the splines in-situ and stave off the problem. A couple of the Adv Rider posters who work a lot on the bikes got so puzzled / fed-up by this spline problem that they sent the parts off for analysis. The lab results came back pretty clear - the input shaft splines are not hardened and that's why some strip. The fit is not particularly good either so if you happen to have one where the tolerances mean the fit is on the loose side then it will fret and strip. Lubing will help a bit but only a bit.
So that explains why some stripped, some didn't, some survived longer with lube and yet others survive 70,000 miles (which is when the engines blow-up anyway) bone-dry and rusty. But it doesn't explain why the shafts are not hardened. I don’t' just mean not fully hardened like a manufacturing fault, they aren't hardened at all. Indeed according to the lab the "soft" clutch centres which are supposed to be soft because they are the wearing part are harder than the shafts!
Having read all that I half expected it to be the problem in this case but as you can see there's nothing wrong with the splines on this one but I happened to mention it to our man on the inside while on the 'phone to him about the gearboxes. He's already come across the spline problem so, being on the inside, he's asked BMW about it. Now before you hear BMWs answer you should be aware that he and I (and you for that matter) all know that any spline interface would NEVER leave the Honda factory unhardened. In the words of the man "Not even Suzuki leave splines unhardened!". The answer from BMW?
"Yes we know but to be honest it never really causes a problem until the bikes are out or warranty and so it is not worth our while spending the money to fix it."
"But what about your reputation?!?"
"BMW already have a reputation for quality."
(Or in other words we don't give a shit if the reputation is completely unfounded as long as it doesn't cost us money)
As the yanks say, Go figure.
And there's many more "shock, horror" facts about BMWs. E.G Did you realise that the "people who make oil" have a VFR800 dyno test-donkey with 700,000 miles on the clock that just keeps on running no matter what they do to it? Whereas the same people, in the same lab with the same tests, cannot, no matter how hard they try, get a BMW to go beyond about 75,000 miles? It's always different faults too, engines blow, clutches fail, gearboxes break, shafts shear. So its not like the bikes have one single achillies heel you can work around / modify, they are just underdesigned and shit.
BMWs - Great to ride, but terrible, terrible things to own.
Was it the RHS exhaust valve?
I think a few people have had this problem, but not a large number. I'd be surprised if the dealer didn't know about it though.
