80g/s headlight
charlie batty
...South Coast Nr Chichester
Well having started off with nothing but the handlebars from Nin ...i've got the levers sorted s/h clutch and new/old assembly from Motorworks including the million pound reservour:blast
got new switch controls, new nacell, speedo, 5 position ign switch plus whole idiot light assembly...
SO ... now i deed a headlight to fit plus whatever is needed to hold it to whatever it holds too:D
Anyone got a suitable item:aidan
When I needed one I was able to get it from our Frankenbike builder, Paul Rooney.
Might be someone on here who does the same ---------1
Check your local bmw dealer.... they still stock the metal ring part and rubber seal that keeps the water out of the nacelle...... or they did a couple of years ago when I did mine.
They may well be cheaper than motorworks/motobins/James sherlocks.
Check www.realoem.com for part numbers etc.
Good luck, and keep us updated on the rebuild
I’ve got a brand new headlamp that’s surplus to requirements, I’ll post a photo later.
...thanks Bubb:thumb2
