A Cautionary Tale - Garage Air Lines and K1600 Tyre valves
peterh
Bath
There I was enjoying my run around Scotland when I had a minor niggle. The TPS was solid on the front, but the rear was 0.1 bar low, most, but not all the time. That poked a stick at my OCD nature, so I thought I'd stop at a filling station and sort it. Simple. Or it should have been.
I found one but it demanded a 20p fee. OK. In went the 20p. On went the connector. Lever pressed. Hiss. But instead of air going into the tyre, air was escaping from the valve. I tried to make a more secure connection, but only succeeded in losing yet more pressure. The more I tried the worse it got.
The staff did what they could. Gave me another 20p to try again. Same result. One went to get a foot pump from her car. That seemed to add a bit of pressure, but as soon as the noise of my furious pumping stopped, the hiss of rapidly escaping air could be heard. 350 strokes of the pump later, I gave up. I moved the bike round the corner, red triangle flashing, 1.1 bar on the TPS.
At that point I might have had only the option of calling out the recovery service. But there was a Plan B.
Out came my 12v air pump. I hadn't used that in the first place because it is a faff to set up. It lives in the bottom of a pannier. The seat has to come off to get a secure access to the battery terminals, and getting the cable back in the space it came from is an art that can waste 10 minutes. (Clearly the makers employ specially trained elves to get the 12v connector and cable into the undersized space in the pump). But that pump had a screw-on connector which I knew was good (as is the foot pump I've always used at home). After a while the tyre pressure was back where it should be. The pump was now very hot, but I had remembered to keep the engine running while using the pump just in case.
Looking at the cause of the problem, the K valve stem is *very* short (and perhaps is on other BMW models where the connector is sideways on, coming out from the spoke rather than the well of the wheel). If a garage connector has to sit deeply on the stem - as was the case at this garage - it is not going to seat properly and all you do is let air out.
The solution was, of course, at home. Aren’t they always! A short tyre valve extension which screws onto the bike valve and has a long reach threaded section for the pump to mate to. It is now carried on the bike.
1.4 psi Low and you went through all that ????
Well, yes. As I said, it just poked a stick at my OCD side. Had I known the time it would take, would I have bothered? No. Did I feel that I had made a foolish mistake? Absolutely.
But ... could knowing about this help someone else looking to use a garage air pump avoid a self inflicted problem? I hope so.
And have people laughed because I have a 12v air pump in a pannier? Yes.
Was I glad I did so? Yes.
Do I mind people poking fun at me? Nope.
Another reason not to have TPS.
I have a sort of TPS system... i check my tyre pressure when the bars start to pull as i lean into bends. Usually happens once the front drops to below 20psi.. Who needs electrics to tell you.
I had the same issue with my RT - had had it less than a week and whilst at the filling station, thinks...while I'm here, I'll check the tyre pressures...the rear (standard 'points towards the hub' valve) was no problem then on the front the air just kept leaking out each time I tried to attach the air line. Fortunately I cottoned on before the tyre was completely flat and as I was only 1/2 mile from home managed to gently wobble my way to the foot pump in my garage. The RT being particularly sensitive to front tyre pressures (I could tell when it was a tiny bit low by the steering characteristics) this was quite a pinchy bum experience; first thing I did was buy an electric air pump which never leaves the bike!
Edit: no TPS on that bike by the way - garage airline just couldn't cope with the length of the right-angle valve which comes out if the 'spoke' of the cast front wheel.
... Do I mind people poking fun at me? Nope.
Essential attitude in here :clap :D
You can keep your technical approach :rolleyes: ~ i'll stick to kicking me tyres. :pullface
Oddly I had the exact same issue also while in Scotland. ..but unlike you in order to secure a better connection with the rod pump...I forced it too hard and damaged the valve. It stopped leaking but I couldn't put anymore air in it. Off I limped at 1.2 bar to nearest tyre place (awesome customer sevice ) to have my electronic sensor valve replaced with a standard ... £10 cash.
On return to England. ..I got a replacement BMW TPS fitted for £140.... expensive mist as ke..not to be repeated !
I've carried one of those right angle connectors for years. Many garage tyre pumps have a fixed end the won't work with a bike wheel - hub gets in the way. Screw on the adaptor & it's good to go.
Feel lucky. Lots of bods snapped their (expensive) electronic valves off. Result? Misery.
