....another thought. Could try engaging a (high) gear and turning the the wheel backwards slightly, which should give slack onto that side of the timing chain. The cam chain tensioner primarily acts on the other side.
Didn't Mummy tell you not to play with things you no nothing aboutI showed my wife what you did
Remove valve cover (or rocker cover) and introduce long flat screw driver under chain rail pry chain rail up introduce screw
Good luck![]()
Thats exactly what we did, two of us managed to "dig" around and lift the chain guide to allow the bolt to slip in.
Now back to the original quandary, where to mount the tax disc
A
st247
Where did you get those drawings from please. Is it a CD, if so how much and what is it called. Cheers
Some people use bolt 1 shown in this picture.Now back to the original quandary, where to mount the tax disc
Nice oneThats exactly what we did, two of us managed to "dig" around and lift the chain guide to allow the bolt to slip in.
Its called the RepROM - the BMW maintenance manual CD. You can pick them up off ebay for less than a tenner.st247
Thank F*ck that's sorted I was panicking there for a while, so god only knows know how you must have felt.
And who the f*ck mounted the holder there in the 1st place anyway?
P.S. Today is national swearing day (In my head)![]()
Oberon Engineering tax "disc" holder.....
Looks the "dugs danglies" Does it not interfere with gear changes?
Nope, I forget it's there....![]()
