ABS modulator relay
AndrewD
Slough UK
ABS has always been a bit odd on this bike, thought it was the battery so used to start with the ABS disabled and wait for it to auto reset a few miles down the road.
Having changed the battery it will not set on ignition (not started) and will not reset on grounding the pin etc... No "K-Klunk" on pulling away etc and 6 flashes on the diagnostic to an LED...
I've bled the system including the ABS pump and stripped/cleaned the modulator pistons so it is looking like the big relay is kaput in the modulator.
Does anyone have a spare or know if it is available as a generic item, as BMW don't sell it (mind you Bahnstormer in Maidenhead could not find dash bulbs on their system :blast) and motorworks are not sure if they have one either.
What year is your bike? R1150GS ?
Do you mean this?
BMW has spare part number 61 36 2 306 526.
Number 5 for 1999 -2002 bikes.
Here are the bikes it suits.
http://www.maxbmwmotorcycles.com/fiche/PartsSearch.aspx?parts=%2061%2036%202%20306%20526
Pekka
:rolleyes::rolleyes::rolleyes:
Bike is a W reg so 2000
Cheers, it's not a plug in type but a relay with bolt tags, more like a starter solenoid...
Here's the little devil...
That base is not a socket for the relay, but a support for the tags and even has a diode running through a hole through the housing.
