emjay
Nipped out to the chippie ABS didn't set but that's not unusual so as its only a short trip thought it would be OK on return but no it still didn't set.
Anyway could hear a noise from under the tank like an electric motor, switched off ignition "motor" still running tried pulling fuses no joy, so its disconnect battery. So the culprit is unfused and not wired through ignition. It's something in the ABS see pic below tried reseting ABS no effect.
So any ideas please. It's a 2002 std 1150.
