ABS SWOP🫣
Baza 07
Wirral Merseyside
Ok part 2, I’ve hit it, swore at it,and bled the system with my Motoscan it freed it twice but that was my lot, does anyone know what Ford ABS unit fit’s please, Cheers Baza 🤔👍
Its just the Motor not the whole assembly
Thanks for the reply and the link, some great info there,wether I could do it is another thing,there’s some great home mechanics on here,last couple of questions, as the brake failure light has been on for years,and the small amount of miles I do,ie under 2k a year,dyou think it’s worth doing, 🤔
Had the Motoscan app on it yesterday and in the trouble codes these numbers came up
Pump Motor Voltage Supply
5DFO
5DF1
I’ve Googled it but not to sure what the fix would be 🤔
Thanks again for your input 👍👍
Cheers Baza
Oh look they even agree with what I said in 2017...
Common problems​
  • Error code 5DF0 and/or 5DF1
  • No communication with ABS ECU possible
  • Error code 5DF5 (BMW)
  • Malfunction on pump motors
  • Locking up of one or multiple wheels
Cheers botus, so what and where is the Ground Cable🤔
Also I’m thinking of going down the new brushes route, do I have to fit a new bearing,as I’ve got no puller ☹️
Cheers Baza 👍
Found it 🤯🤬😭😭😭
Cheers Baza 👍
Found it 🤯🤬😭😭😭
Baza Just change the feckin Motor!!!, you have to split it to get at the Brushes anyway !!
Never mind feckin Ground straps and the schite that Balloon comes off with!!
I have no idea why the brushes stick or fail But the motor just does and the brakes with the Fiesta Motor were soooo much better When "Needed"
You have to take it out to do any work! So just make sure and seal the lines from debris and dust while you are at it Old brake nut will likely be in the replacement ABS block as no one will likely just sell you the motor so you can seal the Bike ABS unit from dirt and debris ingress too
:ROFLMAO: Ok Doc,now i'll have to go looking for a Fiesta,really appreciate your help and advice,as with everyone on here (y)
Cheers Baza
