jenslh
Hi Jens,
I copied the following statement from your site:
"This means that within the temperature range where people actually consider riding their bikes, the serial resistor will add from 3% to 10% fuel. Not exactly the high tech solution some of the Scammers are promoting."
I guess what you're saying here is, at very hot ambient temperatures a serial resistor will add 10% more fuel.
Again I quote from your site:
"This means that if we're running the engine at 14,4:1 and we add another 6% of fuel, the calculation will look like this:
14,4 : (1 + (6 : 100)) = 13,58 : 1"
So if we make the math for 10% more fuel:
14,4: (1 + (10 : 100)) = 13,09 : 1
Are you sure running the engine at 13,09 :1 is extremely rich and will wash the oil film from the cylinders?
cheers
Tolga
Going from 14,1:1 to 13,6:1 will be a positive experience for you and your bike. Going down to 13:1 will not improve anything but fuel consumption, but will on the other hand not harm any engine.
However, you should note that the 10% figure is just from my example, where the resistor was tuned correctly for 20 degrees. If the resistor was tuned for zero degrees celsius, you would see up to 20% fuel added on a very hot day. Now we're down to 12:1.
My point is that you could harm your engine if you or the provider of your preferred tuning device does not understand how this works.
What we want is a stable enrichment, regardless of ambient temperature.
/Jens
- but I sincerely hope that one of my customers will do the samme test and publish the results.
