Accessory Socket
  • Thread starter Thread starter suipedali
suipedali
Is the accessory socket live when the ignition is OFF, on my GS. Sorry for such a dull post!
is it on a 1100? as i use a standard charger plugged in and it works ok, i thought with a live feed while ignition off it wouldnt have worked???
It's on a 1150. I want to use an optimate battery charger via the accessory socket.
Not sure what you mean by 'live feed' but on an 1100 the socket has a permanent (fused) connection to the battery (unswitched by the ignition). It'll happily provide power to accessories and receive power (from a charger) with the ignition on or off. Whether it's advisable to power stuff via the socket with the ignition off is another question :rolleyes:
You'll be fine doing that.
I believe there's some sort of issue with 1200's which requires the charger to trick the canbus into keeping the feed to the socket open :nenau , but that doesn't matter to us.
I have been using an Optimate 3 to charge my 1150 via the accessory socket for 3 years with no problems. Just need to get one of the plugs to fit the socket and wire the optimate cables to it.
:blast:blast:blast:rolleyes:
Optimate do a specific bmw plug
:augie
:augie
The 12v DIN plug is available on every street corner for a few quid. It's easy to wire to an Optimate connector - but make sure that you get the polarity correct.
Alternatively, buy one of these:
- it's a fag-ash to DIN convertor. Available here
Greg
