- Joined
- Nov 5, 2015
- Messages
- 13,534
- Reaction score
- 5,765
Stick a screwdriver on the head and have a listen, if it sounds OK it’s probably OK, it’s a Honda
I think it’s worth checking at the first recommended interval, then if they are well in spec it’s up to you whether or not to bother at the next interval; eg my bike was cock on at 18000 so I won’t bother looking again until, say, 50000..........unless of course she starts getting hard to start/whatever.
That may be deeply flawed but it works for me.
Andres
They will be perfectly ok - modern bikes have been engineered not to need them checking any more - to at least 75000 miles
The mileage recommendation is to keep the dealers sweet.
As my bike is laid up for the winter and as it had passed the 16k mile service advice, I’ve taken the plunge and decided to strip the bike myself for this major service as I’ve a good mate who can do the actual valve check. I’m fine up to a point in servicing, but always leave the really technical stuff to those better qualified. But my god, I’ve never had a bike that needs soooo much taken off it to gain access to the oily bits. Although the Honda workshop manual doesn’t say the rads need to come off, the sages say it’s much easier to do the check with them removed. So far.....
Seat, fairing, tank, air box, throttle bodies, coil pack tray, radiators and loads of other bits and bobs have come off. It’s no much wonder that Honda apparently charge £500+ for this service (allegedly a 9 hour job).Fek knows if it’s going to ever run again by the time everything’s bolted back together.
I hope that's not the case hardening wearing off on your cams![]()
Surely not
That's not very Honda is it
He bought Honda as he deemed it more reliable than KTM
You are a Naughty man![]()
Sorry to disappoint you both, everything is tickityboo....![]()
Good, if Honda cant make a simple bomb proof parallel twin then no one can![]()
