Airhead 80-100 G/S Adventure Build
A quick out of hours PM to Mikeyboy …. Special service tool no 1 and no 2
Tap tap and out they all pop
Then assemble and bag up the new ones, ready to fit.
A few steps forward and a few back in the last few days.
In an idle hour I got all the new hoses into the airbox
Then started to get the upgrade (post ‘85) rockers fitted to replace the originals.
Got all the parts laid out
Who can spot the conundrum?
Bollox- on the blower to Motorworks immediately, who couldn’t have been more helpful (thanks Stuart).
Apparently this is the second time a part has been incorrectly bagged at BMW, so now they have to check every part they get in fromBMW before it goes out.
Today’s post delivers the right one .
(I just put that in to wind up Mikeyboy)
Push rods in after goosing up with oil
Tighten up and measure clearance - looking for 0.03-.0.07 mm between the nylon bush and post.
Tight sliding gap was 0.6 mm so in go 0.55 mm shims
Button it all up again to torque - remembering to mark off each one as its torqued cos I can’t remember anything these days.
Ah but just realised I’m waiting for the camshaft carrier bearing to arrive, so let’s go to the back instead.
Don’t forget to fit this little fecker before the gearbox goes on or you’ll have to take it off and do it again…
Well that was easy.
Next it time to fit the block vents
FFS don’t drop this
In here
Phew. Probably should have done that much earlier in the process to avoid the stress.
Cheers Mike - yes I found that in the bag taped to the box. That’s an old photo of the switch. Good spot though! Did you like the head gasket …
...in my ignorance i didn't know a neutral switch went there...until I found an extra hole with no nice S/S plug in it:D
Managed to get it in by supporting the engine/box with a jack and sliding the rear engine bolt and central fat spacer out ... was a ball-ache though but worked:aidan
Got a bit ahead of myself with the gearbox mount and forgot to put the lower air box in - sorted now.
Then all the new hoses etc
Finally offer up the cover to see how it looks
Before you put the airbox in, you need to put the cross over balancing petrol pipe under it.
But you knew that.
