£25posted.
An air cushion for comfort over style! It is self inflating- don’t ask how, it must be magic- but it works and can be adjusted on the go. As with other similar products the advice is to set the pressure as low as possible. The cushion measures 33cm front to back, 32cm wide at the back and 18cm at the front. Just sitting on the table as I photographed it it was 35mm thick though clearly this will change when you sit on it.
It’s in excellent condition, no tears or scuffs and there’s plenty of length on the underseat fixing straps. I used it on a Tiger 800 and a Honda CB500X.
