Thanks for the link I will read it properly this evening . And check the seating. . It may well be a factor as far as the roughness is concerned. . But surely not total failure to start.. as far as the hoses are concerned. . I have tried them both ways. . Currently they are fitted in a manner where they follow the natural curves ..
I have just arranged to take the injectors for testing tomorrow. . And intended removing the coils etc to get a resistance test. . The coil is going to be a pain to remove! But yesterday when investigating an "intermittent spark I saw one of the low tension cable hadn't been crimped . It had worked for 17 years! .. but I won't rest until I take it off and properly inspect the conection.
Thanks for your input. You were right about polishishing the headers. . One is already disclouring. . I suspect it was running on one cylinder most of the time
Sent from my SM-A300FU using Tapatalk
