- Joined
- Jul 14, 2010
- Messages
- 10,460
- Reaction score
- 3,768
Don't put yourself down, Tetley's started doing it.![]()
Bad man!
Mikey that single tap will possibly not be able to feed both the Dellortos at full chat
It will Just about manage an 800 on bings
It took a while to figure out a running problem about 10 years back Until I figured that tank had been repainted and I asked the bloke and he said He couldn;t afford a twin tap replacement for his that had a leak So he bought that one cheap off a bloke that he knew who had it lying (A single tap)
Solution until he got a replacement tank was to use less than 4000 RPM for extended periods or when it started coughing to slow down and let the bowls fill up again
I tested it with my twin tap tank and it was fine
I’m not saying you are incorrect ,
However
