Another tyre sealant question.........
jonnie comet
Sunny Scarborough
Has anyone used any of the get you home ( Finilec ? ) type tyre sealants ? ......Good ?, bad ? , use this, don't use that. I have the B*W kit, but on a cold wet night.....etc.....etc.....
Opinions appreciated
Finilec etc...
Have used Finilec aerosol in various inner-tubed tyres over the years and with pretty mixed results. It is a get you home temporary fix, when it works!
In my experience of 8 or 9 times, this stuff worked about every other puncture, ie allowed you to limp at reduced speed for a few miles to the nearest airline to get the pressure back up to normal. Then I got the tyre fixed properly or more usually the tube replaced asap.
I still carry a can in the pannier on my 80G/S, but knowing it has a 50/50 repair liklehood, but in the middle of nowhere, it is something. The puncture outfit, handpump and tyre irons that I carry are more effective!
On tubeless punctures on my oilheads, it is easier. The standard MbW mushroom kit works well, 4 times in 5 years, all were good repairs that lasted the life of the tyre. I get it double checked at a tyre place asap after the puncture for peace of mind, but they work well I think.
HTH. :)
Charlie
Try Ultraseal, works every time for me. Except when I have forgotten to put it in :mad: :mad:
Guaranteed for the life of the tyre at speed way over the capabilities of this rider (or the GS). Not cheap, but it does what it says on the box..........
i used finilec about a month ago cos i couldnt find a hole to put a plug in.
it worked and got me home (it found the hole). it only put about 11 psi in the tyre though.get to a pump asap
Here goes - first time on this forum lark :
My experience on a *issing wet day near Ullapool, ran over something metallic and had pretty rapid deflation - < 60 secs, pulled over and injected Holts aerosol repair stuff, put tyre up 16 PSI I later found out - lasted 12 miles to next garage - blew up to 38 PSI with hardly a leak - would have lasted 24 hrs easy - gets my vote.
R1100GS Tubeless:
Stuart O
I use the BM plugs , but carry a tin of finilec type stuff if i'm on a long journey - wouldn't use the ultraseal stuff if you paid me -
11 of us on a tour of Western Ireland over the last May B/Holiday weekend, we did about 1100 miles. 2 had punctures, both had Ultraseal in, it didn't work on either, but the BWM plugs then saved the day and worked fine and with very little effort.
I was tempted to put Ultraseal in but resisted, I think I made the right choice, I'll stick to carrying the BWM puncture kit and my Airman Sparrow compressor.
I have used and tested ultraseal on quite a few occasions, and found a large piece of flint in the rear tonite and not knowing how big I put Ultraseal in before pullin it out, luckily it didn't leak, but didn't want to take the risk
