Bionicmunky
Hi All,
Got 'check oil level' @ 10 miles - so stopped, checked, all ok - oil at about 3/4 max in the window.
300miles ish 'check oil level' again, stopped checked, all ok - again, oil at about 3/4 max in the window.
The manual says it will come up and you should check at next fuel stop.
From the PDF manual:
The readings mean:
OK: Oil level is correct.
CHECK: Check the oil level the
next time you stop for fuel.
---: Oil level cannot be measured
(conditions as stated above
not satisfied).
If the oil level needs to be
checked, the symbol 2 is
displayed until the oil level is detected
as being correct again.
Now as soon as I switch the ignition back on it clears and says 'OK'.
Is this normal behavior?
Thanks,
JT
The readings mean:
not satisfied).
Thanks,
JT
Not a lot mind.
