Apple to USB adapter lead.
Delboy777
In a Remote area apparently.
Do you brainy peeps know of an adapter that will convert theUSB lead of my GS911 to plug into my iPad Air 2. I think it will need to supply power to the GS. Does any 8pin camera adapter do the job ? I think they dont supply power to GS im not sure. TIA
Powered lightning to USB lead
http://www.apple.com/uk/shop/product/MK0W2ZM/A/lightning-to-usb-3-camera-adapter
http://www.currys.co.uk/gbuk/comput...Fw&gclsrc=ds&dclid=CJLSuJP24NICFWij7QodBuILZA
https://www.amazon.co.uk/d/Computers-Accessories/Apple-MK0W2ZM-A-Lightning-USB-3/B01DGDNL2G
If you're looking to use you 911 on your iPhone/iPad via USB, I don't think that's possible.
Believe you can do it with the wifi version.
I have an iPad the adapter and a GS-911 (wifi version). I can test it for you ( using the cable not the wifi) before you buy if you like. I've used the Apple adapter for USB stick access but as said above not sure it will work as the functionality on the iPad version is reduced.
Yes please try it and see how or if it works Joe. Bloody £30 for a short lead ? Thievin cnuts
My Mac will charge the iPhone 7 and give bi-direction data. The connector is USB to Lightning. See if you can find a Lightning to female USB adaptor. Then plug your 911 into that. You could also ask Apple what USB connectors they have.
https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/272788134407
