At work now, but will take a pic or two tonight or tomorrow Doc.
I was on the lookout for a cheap 'n cheerful inner bag....gets the Springer Seal of Approval ??
See you wasted no time getting the stickers on your panniers too. I've put some red 3M Diamond reflective tape on mine, and it really shows up in car headlights. Can't be too visible in the dark .
Must be something to do with the Tardis like properties of a lady's handbag.
...M & S Xtra large bags. Won't fit my dainty 8" & 9" cases...
The M&S liner bag measures 11" wide x 15" long and 17" deep.
Now that's a real man - sized pannier...M & S Xtra large bags. Won't fit my dainty 8" & 9" cases...
I'll have to go down-market and try the Asda brand.!
Surely Mrs Aidan can get all her kit in one of those monster cases ?
Redcap. do you make brackets/boxes for the F800GS?. If you dont then I'm more than happy to have you use my GS800 as a template anyway, Mark(2jag)
Redcap,
If I was to buy Metal Mule pannier frames, could you make a set of panniers to fit them?
Metal Mule do a set of frames and a replacement exhaust silencer which is positioned closer to the bike frame thereby allowing panniers of the same size to be symmetrically positioned...................but then you probably knew that !!!!!
Many thanks.
Ian
Ian, I've got that very set-up, and had a pair of "Ard-Mules" made up to the same dimensions as Skinny Mules (but 30mm shorter) - I've still to fit them, but it's just a case of positioning the mounts to suit.
A pic of one of the panniers:
Redcap,
Many thanks.
Ian
Hi will these fit a Ktm 990 adventure with the ktm rack and can you get them done in either Orange or Matt black?
