Autocom Logic L1 loses right channel
uncle dick
Devon, England
Hi all,
I'm having problems with the above in that the right channel intermittently disappears for both the rider and pillion.
Any thoughts?
Dick
Haven't tried with music but certainly happens when we're talking. For both of us the RH audio is lost when listening to yourself or the other guy - does that make sense?
Dick
Dick
If you have had the unit for under a year i would ask autocom to check it over for you! If you have had the unit over a year then start by checking connections inside the unit, you could replace the Rider and Passenger leads if its an older unit, i refer to the leads that go into the unit itself. WD40 in the extension heads or a water repellant can also help! :eek:
Regards
Mick
