Not such a big deal snodog, especially on a GSA. There are quick couplings on the fuel lines, so if you make sure the tank is not full (30 liters of fuel is quite heavy
) there's not much to it.
First you take off the seat (I'm sure you can do that).
Then you call a friend and have him take off the black plastic side panel (simply pull, no screws).
Next you ask him nicely to remove the one bolt that holds the tank on the right hand side (tools required are in the GS toolkit) and undo three quick couplings on the fuel hoses and the wire connector.
If he can lift 5-10 kg on his own, he can then take off your fuel tank. If not, give him a hand.
Finally, offer him a few beers
. Not too many, as he might not be able to help you put the thing back on then.
Now you can call another friend to watch you do the wiring. If you're installing an Autoswitch, I could send you a few pics of when I installed mine. It's quite straight forward, unless you're colour blind. Then you'll have to find a friend who's not
If this sounds complicated, find a friend who'll do it all for a few beers more. Or cross the pond and make a nice trip to Belgium, I can give you a hand too.
) there's not much to it. First you take off the seat (I'm sure you can do that).
. Not too many, as he might not be able to help you put the thing back on then. Now you can call another friend to watch you do the wiring. If you're installing an Autoswitch, I could send you a few pics of when I installed mine. It's quite straight forward, unless you're colour blind. Then you'll have to find a friend who's not
. Just need to pick out some nice lights - probably go for the Hella FF50 or FF75s.
