ghiribizzo
I had a quick look using search and didn't see a ton of same problem posts - so I presume this is not too common.
Looks like just one of those things that the Warranty is there for but it's not inspiring.
I hadn't been able to use the bike for nearly a month. The bike had been turned off with the aux lights 'on'. It started no problem but I then realised that the aux lights weren't working. I thought it was mebbe low battery voltage but the headlight came on no problem. The lights were all changed to HiD units.
Realised that if the switch was pressed lightly the lamps would come on and the small green indicator would light.
A bit poor if the switch's contacts are failing if left 'on' for a month.
Not even Guzzi manage that level of crap quality.
Anyone else had problems with the switch?
