Aux plug - max current draw?
Santa-2512
Omnipotent one
North Pole
Anyone know what the max current can be drawn from the accessory plug in the headstock ?
I'm looking at a nav project which needs to be perma powered but i dont want the canbus to have issues
Forgot to add it will be continuous current draw,
Or will i be better off going direct to the battery
Canbus is no problem for running anything if you use it to switch a relay supplying the load.
I have heated clothing, extra lights and satnav all ignition switchable from the canbus. What you do is put a small fuse box in with power supplied from the battery via a relay. The relay is controlled by a piggy back feed from the aux socket. So it's just like everything is running from the canbus and if I forget to switch off all or any of the added kit I don't get a flat battery because the canbus has swithed off the supply.
