Auxillary lights for the Himmy
AdrianS
Harlaston Staffs
Has anyone fitted some spots or fog lights on the Himalayan 411?
If so, which ones did you use?
I note Hitchcocks do a kit which is quite pricey. I just wondered what alternatives are available.
I’ve fitted a pair of Oxford ones to a 411 himmy. Not a bad job actually
Not a himmie, but I can recommend a Denali DialDim as a controller, or a cheaper alternative would be the Skene IQ
Both allow you to dim the lights as DRL, but full beam when the bike has full beam on...
I've had this setup on 2 bikes (V85TT and V100), I transferred them over with my S4 lights. .
The DialDim is imo better solution, but more expensive than the Skene
I’ve just looked at the Hitchcock kit, which Is actually Givi. It looks the same as the ones I fitted. I’m thinking I was wrong about them being Oxford ones
Anyway, personally I’d just fit that kit, nothing else. No need to over complicate things as you have limited generator output
