Avoiding motorways
Doc
Ey Up
Slawit
Hi lads,
Putting avoid motorways when I do a route and it's still wanting to send me down them ? Put avoid and it's gone off.
What app are you using?
When i unselect motorway its works on MRA and Google maps.
However this is best done before you set off.
For example if you decided to avoid motorways while on a slip road, it has no choice to start you on the motorway and then take you off.
So sometimes it can depend where you are when you change the setting.
  • Like
Reactions: Doc
I think Doc is using a Tom Tom
  • Like
Reactions: Doc
But do remember that the sat nav will take you up every B road, which can be “‘interesting” especially when the grass is growing up the middle of the road. A lot of roads here are ok on the bike, but I would not want to take the same routes with the car. 😁
  • Like
Reactions: Doc
The routing algorithm is better than it used to be.
In the past i have been sent through farms and private land, as well as the footpath like roads lol
Last year or 2 its not been so bad, unless I've just been lucky.
  • Like
Reactions: Doc
Re read your question you have probably already done what I said. If so cant help. Other than doing a update or reset of the app on your phone sometimes sorts things out.
  • Like
Reactions: Doc
Sorry should have said Tomtom
