Hi Richard - I am using a Mac to to do this
I find the search result I want and drag it across into the folder I've created for that particular route (or set of routes). It then seems to be stored as a place with a flag next to it in the file. I can then use that point as many times as I like in the "create route" function as a start, finish or intermediate place - you just simply drag it from the folder into the route box. This stops the need to do the same search again to find your start point from the place you finished the night before
That's the only way I know how to do it, but if there is another then would be good to know!
OK, I now see what you mean.
I do it that way and slightly differently, too.
I have all my Favourites in one file, or whatever it is a Mac calls it. It's quite handy and they all show up on one map. If I intend to use a new hotel, I add it first to my Favourites. Then, let's say I wanted to go from Chunnel Exit France (another Favoutite) to the hotel, I would simply highlight the two Favoutites (not bother dragging them into any boxes) and select 'Plot route' between the two points. Sometimes it gets it backwards, giving me hotel to Chunnel Exit France; if so I just invert the route. Then, I drag the default route about to suit where I (and not Garmin) want to go.
I have all the options turned off, so my computer will only ever give me the fastest route from A to B. This doesn't bother me as I always manually pull the route about anyway and / or review it to make dure it hasn't suddenly decided to cut a corner down a dirt track, in what I call a 'Garmin feature'. I sometimes miss one or two in a 350 mile day down country roads but hey-ho.
I find this method of plotting routes very easy. Much easier than the laborious, point-by-point-by-point method I used to use in Mapsource.
The last thing I do is highlight all the points inbetween the Start and End points. On a long route there may be 10 or more. I then turn them all into unannounced shaping points. This avoids my GPS device reading them as Waypoints. Last but not least, I have my GPS device set-up with all the options turned off, including recalculate. This turns the device as close as I can get it to a paper map in an electronic form. All I want it do is show me MY magenta line, MY Favourites, tell me MY arrival distance remaining (in miles) and the estimated arrival time at MY final destination. I have the sound turned off and do not play music or make phone calls. In short, I keep it all as simple and basic as possible.
( blue bike) so thought no way amigo
