BaseCamp does not work....
Wapping
Moderator
Wapping, London
It's completely useless....
Wrong!
I have just returned from a Wander to the very rural Morvan region of a France, using homemade quite intricate BaseCamp routes around the very small roads along the hills, lakes, woods and lanes that litter the area. All of the routes were shared with five other riders, each using different devices and / or Mapsource or BaseCamp on their own computers. Each route ran very well.
The couple of mistakes I did make were self-inflicted, missing a small turning - whilst riding and simultaneously trying to avoid a pothole or tractor - and / or when the device was sufficiently lacking in satellite signal as to make it unsure as to where it was, zooming the map squares around as it struggled to display an inaccurate position properly.
Out of a thousand mile, four days away jaunt, mostly on D, N or C type French roads (all homemade in BaseCam) I think there was one genuine routing error as we approached Troyes on our return leg, where the device tried to send us off a perfectly good D road, down a genuine unmade goat track. I have checked the route on my return. The error is not there in the route I created at home; it can only have occurred when the device imported the route from its own memory, converting it into a route from the original .gpx file.
Even then, I think the error is probably man made, at least in origin. I have looked at our track and at the route. When creating the original route on my computer, I think I placed a via point / routing node right at the mouth of the very small track and another maybe several miles away. The computer with its much bigger computing power was able to plot the route correctly, missing out the goat track. When making the conversion, the device, with its limited computing power, had simply done its best, routing me along the goat track to join two points up.
It wasn't life threatening. The routing error was so obvious, requiring nothing more than a very swift U-turn and then following the signs to Troyes (it helps if you know roughly where you are going) and all was well.
Get to know and love your BaseCamp and Garmin GPS devices. They are both really very good.
PS To the 'I never use a GPS device, I use the sun and my inbuilt sense of direction' brigade. I defy you to have ridden the same very small, often un-signposted, Morvan roads and tracks, with five other bikes in tow, without getting horribly lost or having to stop every five minutes in the woods and lanes to consult your almanac. Yes, 'it's all part of the fun, mate' but that novelty soon wears pretty thin.
And he is not even employed by Garmin! Rather, just someone who has persevered and learnt how do do what he needs on Basecamp
Alleluia brother, join in the evangelical church of Garmin at the alter of Basecamp and you will find salvation...
I agree, works great at intricte routes that would otherwise take an age to navigate without GPS. No doubt the "where's the adventure in that" brigade will wade in shortly but quite frankly I have limited time when on my annual 9 day tour and want to cover the most ground on the most suitable roads. The combination, in no particular order, of Basecamp, ITN Converter and Google StreetView make plotting the optimal route over winter evenings an enjoyable advance taste of the trip to come. There's always plenty to experience that you didn't anticipate.
Aside from following a pre plotted route you can just get yourself lost in any way you desire and just let the sat nav constantly recalculate the route to your destination (best with the sound off). Once the ETA display is at beer o'clock follow it to the hotel/campsite.
Basecamp works pretty well IMHO, yes there are areas where it could be improved like most software out there. For me, in it's more recent version, it's an improvement over Mapsource which I used for years. The methodology is a little different to that of Mapsource so there is some adjustment required. Additionally, it won't consistently plot a good route without a degree of effort from the user, that's not what it's about. Put some time in and reap the rewards.
There is inevitably the occasional glitch though usually minor and most frequently down to human error.
Wrapping, do you have unpaved roads checked in avoidances? Won't always work as the problem maybe a miscatergorised road, nobody's perfect, including Navteq who provide the mapping data. Not bad though considering what they do deliver. I believe Basecamp has a built in way of allowing you to report mapping errors.
Having said the above; If you feel that Basecamp and/or sat nav isn't for you then that's fine by me.
Sent from my GT-I9505 using Tapatalk
I am also of the Opinion that BAse camp is a decent bit of kit !
I plan all my routes using it and have learned its little foibles and know that when it goes wrong it was my fault in the first instance for not plotting properly !
It frustrates me to see all the Base camp is shit postings but i have never used anything else so what would i know.
