Basecamp question
Skid06
notts
is it possible to cut and paste a screenshot of a route/map on basecamp?
I know you could on the old mapsource as I used to print off on there. Just had a look. Under file press print and chucks up a screen to play with. Have fun:D
Having re read your post I am not sure but someone more knowledgeable will be along perhaps tomorrow .
Now if you took a photo of the screen you want to capture iPad or iPhone or real camera and save as jpeg you would be able to do it in that long winded way.
if using a pc on windows open basecamp, set to full screen then hit the print screen key on keyboard, go to start then accessories and open paint, hit the paste button top left your map should appear, you can then save to a format to suit, hope this helps.
If your on a pc you can use the snipping tool, under accessories to create an image of the route
thanks for your help chaps
