Activity profile in map source, you will find it under edit-preferences-routing-vehicle just in case people did not know how to find it, and in basecamp its at the top on the tool bar under activity profile.
Maybe i should have worded it differently, and called it vehicle settings, but i can asure you if you create a route in mapsource when you have it set to Vehicle car/motorbike, and then change it to Vehicle Taxi or truck or bus or whatever and recalculate for each change without altering anything else the route will indeed alter. Now whether or not these changes alter anything on the nav i dont know, but as an activity or vehicle profile they will indeed alter your route, so whether garmin call it preferences in mapsource and activity in basecamp does not really make a difference it serves the same purpose, and will alter your route.
i will hazard a guess here and it is just that a guess, look on any of the garmin forums including their own, and you will see statements saying that the new devices do NOT work with mapsource, and we must use basecamp, and of course we know this not to be true in part, just maybe, the part we do not know about, is the way mapsource interacts with the new units, compared to basecamp, for example sending preferences and the information contained with in, and the function codes that the unit must recognise to make changes, you can rest assured that they would not state to use basecamp with new devices if the old software was 100% functional with them.
Edit, or maybe the code inside mapsource just messes with the new units hence the statement they are not compatable
John. If you read through this thread, particularly posts from Wapping, the thing to do which I have just learnt is to switch off automatic rerouting. Then you can return to the route without it having recalculated. If you go off route with auto recalculation the units logic will prevail over all your hard work in setting up the route.
I tottaly disagree, that is not my experience at all. I find the auto re routing very useful. It only causes a problem if you don't set preferences to suit your needs or you don't plan properly. If your preferences are set properly the auto recalculate just sorts out minor diversions without fuss and takes you on to the next via point on your route using the sort of roads you have requested. It should not ruin your route, it will only change it significantly if there are not enough via points to tell the device where you wanted to go. In others words, if you didn't put any effort into the route in the first place. If, for instance, it is 20 miles to the next via point and you take a wrong turning the device might take you directly there via a motorway, ignoring that lovely twisty B road its because your preferences don't include avoiding motorways.
I have been using various Garmin devices since 2003, always with auto recalculate on. Plotting a route that does not get spoilt by being re calculated is really very easy. I plot a simple route from A to B and then drag and drop the route until I am happy that it uses the roads I want rather that what Mapsource or Basecamp thinks. Most routes only need a handful of via points but obviously if there are alternative roads it pays to put a via point on the one you want. So putting a via on that lovely twisty B road means you won't miss it.
John
Fair enough,that'll work. I thought you were having a problem so offered up a possible solution which also works.
John,
On New England Riders.org I am sure he says he always has his satnav set to car only on the unit and in basecamp. Just one of those statements that sticks in my mind.
Turning off auto re calculate only sort of works if you know where you went wrong and how to get back on your route. It also requires more effort in that you have to plan your own way back onto your chosen route. Not much fun if the reason you diverted was because a road was closed and you are in the middle of a unfamiliar and rather busy city.
Then set it for 'Prompted off-route recalculation' where you (the rider) retain ultimate control, not some dumb device.
It's not very difficult.
If, as you say, you have plotted your route correctly and if there really is no easily sensible alternative course of action - the road you had planned on being shut or being hopelessly adrift in a city, hunting for a specific hotel - then indeed there may well be a case for a recalculation of a pre-made specific route. Those situations are comparatively rare, other than in Germany where Umleitung are of course the order of the day.... And everyone vil obey das odours...
Me? Unnecessary or not, I'd rather decide for myself when that dreadful moment has come and only then tell the dumb device to get me the hell out of Dodge, rather than it do it automatically for me. I'm then in control, not it. You are different.
