As long as the alternator is putting out more than the bike is actually using, then the extra will go into the battery. It might take longer to fully charge the battery, but it will still charge it.
Lead acid battery is old technology (>100 years) and not very efficient for size or weight, but can kick out a heavy current so they have remained for starter batteries. Starting a 1200cc twin will really hammer the battery, hence the physically large model normally used on a GS. Cheaper batteries will work for a while but show the strain in reduced useful life.
Ballistic batteries are probably no better in power storage capacity, but being more efficient are much smaller and lighter. The main benefit is the high current kick. For me that's worth the extra money. For me, the small size is a bonus.
Of course they are not cheap, but given their long design life and small size, when my big Exide gives up (its now showing some strain) Ballistic will get my business.
Both links to you to the same page!
THIS is the link to the very comprehensive test of the Motobatt battery against others, including the Hawker Odyssey.
The fascinating test is where they used the batteries to start a V10 engined pickup. Both the Motobatt and Odyssey started one 25 times on the trot. They continued with the test and the Motobatt succeeded 50/50 times. The Odyssey achieved 45/50.
For a glass mat battery it's astonishng value for money.
i am not convinced yet, they seem more fragile than lead acid and can be damaged severely by over charging or by going low voltage below a certain threshold, in other applications they have controllers that prevent these type of events happening
i have also seen advice not to use them in very hot climates
having said that let us all know how you get on !!
