If you are about to change the timing chain, setting up the ignition timing should be a piece of cake for you! But mark the position of the bean can before you remove the bolts that have, er, already been removed in your picture! The Haynes manual is really good on this but you need to read all the relevant stuff before starting, so you know if there's a special tool or 6 that will speed the job up....
