I don't want a flamewar, Just information.
Prophet
Edinburgh
Hello fellow tossers, dentists and miscreants.
I know starting a thread about Oil will start flamewars, but that's the problem. I've read through 20 years worth of arguments and I'm no further to understanding than I was before I started reading.
I bought this Oil to change my R1150GS's oil since it hasn't been serviced in who knows how long. https://www.ebay.co.uk/itm/111701579402
It's 20w50 Mineral oil, and from what I can see that's kind of the consensus, but I don't know if the API specification is wrong on it, some people said it doesn't matter what oil you put in it, some people say it does. I don't know. It's SG/CF API.
Just I've used this brand before in my old bikes and never had an issue with their oil, it performed well enough.
Thanks.
Co pilot response.
API SG/CF is completely fine for a BMW R1150GS.
The R1150GS "Oilhead" engine relies on older, traditional oil chemistry, making this specification a solid match:
API SG (Gasoline Spec): BMW originally specified API SF, SG, or SH for the R1150 series. API SG is high in ZDDP (zinc and phosphorus), which protects the R1150’s flat-tappet cam followers from scuffing and excessive wear. Modern automotive oils (API SN, SP) reduced these anti-wear additives to protect modern car catalytic converters, but SG retains the heavy protection this engine likes.
API CF (Diesel Spec): The "CF" rating indicates heavy-duty detergent and dispersant additives designed to handle soot and thermal breakdown,
Your mineral 20W50 oil is just fine for an agricultural tool like the 1150 GS..
She makes noise and rattles even when warm, thats all normal…
Watched a documentary on BMW building the 1000 RR in Berlin Factory.
Those engines are made to 7 micrometer tolerances, just imagine a human hair is between 20-40 micrometer.
They need highly specified oils…..not the 1150…..I have used a 10W40 semi as top up,
but stick to mineral 20W50 for an oil change.
No problems.
No problems.
A 7 micron tolerance is a reflection of the capability of the manufacturing process. (And sounds a bit tight to me, as process capability studies require that to allow such a tolerance the process would need to be capable of achieving less than 4.2 microns in normal circumstances - typical CNC machines are around twice this - though grinding processes can achieve it in normal production)
It has nothing whatsoever to do with the clearances between parts, which is much more relevant to the oils.
There is no easy answer to this one !! as Its the everyone has an opinion / Asshole type of thing
But My tuppence after working on them for 20 plus years, CF is pretty much all that is "easily" available these days and even that is becoming hard to get and all of my bikes have run on it for 20 plus years
If you are going to keep the bike ??Try your local motorfactors and ask them to get you a case of 4, OR a 20 litre drum of an SG grade If you are not happy with SF
Personally again!! If you are just riding the bike and not riding it like you stole it every minute of every ride ??
Fresh oil of and adequate amount is way better than low oil or Dirty oil and if you have doubts change it at 4000 rather than 6000, Its your call
I ran my 1200 on that grade too !
Oh and don't keep filling the oil level to full !! Park it on the sidestand after a run and let it drain down a bit from the oil cooler!
If you can brave it out? They find their own oil level Where they basically stop using oil so much !!
There are two half litre paint pots flying up and down and the crank smashing the oil surface and basically vapouring anything that is in their way
My 1200 was a prime example even though I should know better I was worried about fragile the Mk1 were
And I did the religious top up thing and ended up at about a litre and a bit between each service
Caught myself on when my mate reminded me of the above and that dropped to "maybe" a 1/4 litre between services !!
I don't think that it's nearly as critical as people try to make out. The manual itself gives a wide range of oil viscosities.
For my own part I will use anything from 10/40 to 20/50 either mineral or (more normally) semi-synth and they don't seem to suffer from it. I ride mine every day is all weathers and temperatures, a lot of stop-start (because it's a mix of fast road and London traffic), I put 82k on my last bike and it's still going strong 2 owners on.
By far the most important thing is to change it regularly.
I ran my first hexhead on viscositys ranging from
water to grease (well not quite grease)
The understanding was its a tractor and is more than happy on mineral oil, you can run SS but why bother
specified thickness was 10/40 with lots of up and down in the thickness ratio supject to the minimum letters
i ended up on 10/50 with the correct letters ( some strange info on the letters) ?? the llater the letter covers the the preceding letter ?
Anyway being a tractor it didnt care and it became no longer noisy when we got to 27 degress c
Non co pilot response... Yep... I'm on Morris at the mo, have used others, they are tractors and are very hard to break... The reason oil threads get heated haha is it's usually worrying over nothing... Like 99% of Jap 4 stokes using 10w-40 semi synth MC Oli of any decent brand...
Thanks.
Your biggest problems are that you are:
A: Massively Overthinking it
B: Asking the internet
As a Dentist, wouldn't you advise your clients to use forums and Facebook for Dental advice ?
"I've been brushing my teeth with this toothpaste for years. You should too"
You get the idea.....
I wouldn't use mineral oil. It's old tech. For vintage and classic bikes.. Your 1150 isn't a classic bike. It uses the same engine materials and technologies as modern engines.
Will it do any harm. No it won't. It will be fine.
Is it the best for longevity. No it isn't. But it will still probably outlive all of us.
In my workshop, I've been using fully synthetic 15w/50 in hundreds of your generation for many many years. Like most workshops.
Don't get obsessed by API classes. Oils are getting better and better. The higher up the letter on the alphabet, the better the oil.
Westway, Smith and Allen are absolutely good quality oils.
Grab 4L of their semi or fully synthetic 15w50 oils and just get on with your life.
Or just use what you've already bought and life will be easier again.
In saying that!! When I was in the workshop doing PDI on the first two Hex Head 1200GSs Feb / March 2004 (We actually had to hide them in the back of the workshop under covers for a few weeks before the launch !! Such was the enthusiasm back then!)
Anyway The fancy launch pack with all the workshop instructions Stated 20W50 albeit SG grade back then
Yep and when I sold 1150s they came were PDI'ed with what was probably 20w-50 mineral and then serviced with 10w-40 Castrol GPS semi synth with their Castrol tie up... And when they ran out of GPS they used 20-50 again...😆 Then BMW changed their minds or something...😆 I used 10-40 for years, then 20w50 or sometimes 15w40...😆 No blow ups or shiny bits to report in 30 years of old tractors. Just more or less rattles...😂
Probably the most important bit for oilheads when new is they actually had oil in them....😂😂
I had thought of mentioning the Switch to Fully synth but I think that was to up their turnover with the pretty amazing fall in revenue after the Northern Rock Debacle!!!!
It nearly put my lights out! everyone put their bikes away or sold them and no one was buying new!
And most definitely no one was going touring 3 and 4 times a year :(
Hi Everyone,
Thanks for the response. I'm glad I haven't bought the "Blow up your engine" 20w50 like some people online thought so, Also I said dentists because it's what I refer to other GS riders as, If I'm seeing someone on a R1300GS Adv Triple Black in full Milk gear (spell it backwards) I'm assuming they're a 45 year old dentist to pay for all of the gear :)
Battery has drained in the GS because I left it sitting for a month, so it just clicked the starter motor while trying to crank. Got a new battery on the way and I'm going to try and jump the starter tomorrow to get it fired up and take it for a ride to do a full service on it.
1) Thanks for the response. I'm glad I haven't bought the "Blow up your engine" 20w50 like some people online thought so,
2) Battery has drained in the GS because I left it sitting for a month, so it just clicked the starter motor while trying to crank.
1) What do you mean about the 20 W 50 oil ?? perhaps sarcasm but just wondering as I have over 200 000 miles on 20W50 with no issues except 1200 Hexhead and that was not the oil :(
2) It is very important with these bikes that you do NOT continue to crank if you have a low battery situation! Low volts means high amps and heat and "spikes"
Sorry for the delay, It was just sarcasm. I done my oil change and it helped a lot, bike is a lot quieter now. New Battery fixed it, old battery was at 9v lmao. Ran into a new issue now that I'm going to make another thread for.
Watts law perhaps ?
With lower voltage you need more amps. And And vice versa.
Off the top of my tired head
Unless the resistance of the starter motor changes the current won't increase
Current = volts over resistance
For an increased current at 9V the resistance would need to go down a lot.
Think of an incandescent torch, as the battery voltage lowers, the bulb does not magically draw more current to stay bright, it dims. This is analogous to the starter motor slowing as the voltage drops due to fewer amps and therefore less power.
