What is all the fuss about?
The biggest confusion is getting the right pattern out of the couple of options. One of the joys of the 1150 is the engine braking which makes the need to actually squeeze the lever redundant. I have gone from the Peaks to Falmouth (home area) without using the brakes more than a handful of times in the entire 300 miles. Back off the throttle and avoid the brakes altogether.
I even went across into the hills of Shropshire an dback with no brakes at all once - I had to for a job, but I had little worry. The servo motor had given up the ghost and I literally had zero brakes. Just a good eye ahead and a riding within my limits and I never felt vulnerable at all. A tiger might have jumped out from behind a pine tree and tried to savage me, in which case I would have be glad of some brakes.....but life is full of possibilities.
The biggest confusion is getting the right pattern out of the couple of options. One of the joys of the 1150 is the engine braking which makes the need to actually squeeze the lever redundant. I have gone from the Peaks to Falmouth (home area) without using the brakes more than a handful of times in the entire 300 miles. Back off the throttle and avoid the brakes altogether.I even went across into the hills of Shropshire an dback with no brakes at all once - I had to for a job, but I had little worry. The servo motor had given up the ghost and I literally had zero brakes. Just a good eye ahead and a riding within my limits and I never felt vulnerable at all. A tiger might have jumped out from behind a pine tree and tried to savage me, in which case I would have be glad of some brakes.....but life is full of possibilities.
