Burfcontrol
First a question, then a bit of history as to why I'm in this position.
Has anyone reused big end bolts?
Did you have any failure as a result? How many miles have you done since reusing them?
I know it's a big no no. I understand they're stretch bolts and should only be used once, but I've been given the wrong ones from my dealer (I won't name because they've been very good over the years and I haven't had a chance to let them explain).
So is the risk that they'll shear or work loose? I've used loctite on them so if it's the work loose issue will I be OK?
I'm sure I'll end up going back in and replacing them, it's just the thought of another week in the car and tearing the bike down again having just spent a week with it in bits is hard to take right now.
The story so far....
Had an inlet valve/piston interface incident - left side, happened cruising at steady 65/70 mph on motorway. Got lucky, only bruised the piston and no damage to valve. Bike was still running and ticking over, very loud tappetty noise, oil pressure and temp OK.
Checked compression, good and same on both cylinders, so no sticking valves.
Calling various dealers had different theories as to cause. One suggested worn big end bearings (bikes done 100,000 miles, 1150 single spark, 2000) another debunked this theory saying they'd had bikes with completely worn big ends and no piston contact, which made sense as normal clearance would have to be very tight for this to have happened.
Called the oracle - St Eptoe - who as allways gave as good advice as he could without seeing or hearing the bike, suggested valve timing and common cause of this would be over reving. (Sorry if I didn't get this right Neil, it was last week and my memories not as good as it used to be ) I couldn't see how this would relate to steady cruising speed but it would explain the valve contact and steered me in the right direction.
Went to see a local engineer whose been working with Boxer cup team, we stripped the head and valve gear at his shop, no sign of any wear or pick up on any moving parts. Again theorising valve timing but couldn't figure out how it could advance at steady speed, would expect it to retard and usually jump a tooth at start up.
Put it back together without pistons and conrods and checked valve timing - lo and behold the left side was advanced about 30' - the right was spot on.
So retarded the timing by one tooth on the sprocket and rechecked -
Reassembled everything, fitted new big ends and rings at same time as I was that far into the engine.
Fired up, gently warmed up on centre stand, ran OK but still had louder than normal tappetty noise from left side - nowhere near as bad as original problem but still louder than should be.
Conclusion - rang the Boxer cup engineer who had asked me to let him know what I found. We now believe the left side cam chain tensioner is 'lazy' (his words) causing the tappetty noise and potentially allowing chain to jump ahead one tooth advancing timing and causing inlet valve to open around 30' before TDC.
I'll get a new one ordered tomorrow and see what happens when I fit it.
Cheers Jim
Cheers Jim
