To all those that have experienced hot start problems; do your bikes always crank over perfectly well on the first start of the day?
I can’t believe this issue is always due to batteries being depleted so much after just one cranking episode that any further start attempts are compromised, unless there is an unusually high percentage of feeble or tired batteries out there all of which are fitted to GS’s.
Even a regular battery in average condition should be able to perform a handful of start attempts even without the benefit of being charged for a few miles afterwards once ridden.
I reckon it’s a starting system with many borderline components all suffering from the ‘Swiss cheese effect’..
No, mine started having problems when only ~ 15 months old. Flat battery, can't cold start. and stupid warnings about the SOS, and other random electrical issues.
Everyone blamed the tracker "they run down the battery sir", well, not according to Datatool they don't.
In the end, I had a new alternator fitted. It was better. I noticed it only had a problem in the winter - two observations, if the weather's crap, I have the heated grips on, and I only ride to and from work - about 5 miles each way.
I gave up the unequal struggle, fitted a socket and use a trickle charger when I leave it in the garage over the weekend. I have had a few warm start issues (at the petrol station on the way home, for example) since, but in general it doesn't fail to start when I'm going to work. I have also fitted a new battery - Tayna, the 240Ah one. Still have issues, but rarely.
I say warm start because it is not a 10-15 mile ride which would get everything up to steady working temperature.
I conclude that the charging system is marginal, and it was simply not making up for the energy used to start, particularly with the extra load from the grips.
Additionally, the battery is too small.
Maybe there are bad/high resistance connections which I have not yet found, which might be making charging and starting less effective than they should be.
And maybe the starter motor and decompressor thing don't work reliably together when the motor is hot.
Mostly it's ok, but it is a ballache when it isn't.
