Bigger Valves – 1150GS
DrAlf
Redbourn
Does anyone know of a source of information that details that valve sizes used by the various 1150 and 1200 oilheads? I’m looking to possibly increase the size of the valves on my trusty 1150 – any info would be greatly appreciated.
Thanks in advance
Adam
Thanks Mouse. Not a great deal of info out there on 1150\1200 valve sizes. Still looking….
PM sent now shut it :D Back on track - valve sizes anyone? :rolleyes:
1150 gs
Valve head Dia Inlet 34 mm, Stem Dia 4.966 mm, Valve head edge Thickness 1.00
Valve head Dia Exhaust 29 mm, Stem Dia 4.956, Valve head edge Thickness 0.9 mm
Both valve seat angles are 45 Degrees
Dont know about stem lengths
Cheers DD :beer:
Thanks for the info. What I really want to know is do any of the 11xx series oilheads feature bigger valves than the standard 1150GS? If so, is it worth fitting heads that feature bigger valves – what kind of performance increase can I expect and what else would need to be done to the bike – just a chip?
Please don’t tell me to go out and buy a sportsbike :rolleyes: – I love my old GS but sometimes I feel it could do with just a little bit more go
Thanks in advance:thumb
If you try here http://www.maxbmwmotorcycles.com/fiche/fiche.asp you can compare the various engine parts for the different models, I think the RT and RS use different pistons to increase the compression and a different cam profile to give more top end power, this may or may not be at a detriment to the mid range that the GS has, Dyno charts anyone? The inlet snorkels are different diameters and lengths on other bikes as well , you need to ask someone who has carried out this kind of work already and ask them the best starting point.
Cheers DD :beer:
