Sylvester
Hi Folks, just recently retired and moved to France. My bike seems to hate French fuel. It’s a R 80 GS paralever. Engine has a Seibenrock 1000cc conversion with the heads/pistons machined to match by Steve Scrimminger. Still has the std carbs and was running ok in Germany but now pinks like crazy at higher rpm and under load. I can ride around the pinking, but that’s not a long term solution. I already retarded the timing a little in Germany. Plug colour looks ok and in know it’s not running too lean. Starts and runs ok apart from the pinking. Was gonna raise the needles a notch and try retarding a little more. I had the compression checked in Germany and the graph read 10.5:1 but I have no idea how accurate it was. It was done to see if both sides were the same. Any other ideas?
