OK here’s the problem. R1150 twin spark 03 starts to miss at above 5000rpm. Hardly noticeable at first but it got to the point where it would randomly cut out above 5000rpm. Up -changing or down-changing brought it back to life. Fuel pump noise is a higher pitched than normal. Limped home from Llangollen last weekend, searched the forums and discovered possible coil pack problem. Bought x2 new coil packs. Replaced them both and bike would hardly start, when it did it would run on one cylinder and immediately conk out at idle. Changing the coil packs back, bike runs on one then conks out. Only one down-pipe gets hot. If I pull out both coil packs and just run on the secondary plugs – same symptoms. All spark plugs appear to spark when placed on cylinder heads (i.e. not under compression).
I suspect hall senor failure – I’ve sprayed WD40 in all the hall sensor wiring loom connectors but same symptoms.
Am I on the right lines here? Has this happened to anyone else before? Anyone got a hall sensor they’d like to sell me?
As always, thanks in advance
