BeemerBaz
Plan to respray Matt Black today but other than a rub down and a soapy wash before I spray is there anything else I should be aware of ?
TIA
TIA
Ideally you need to wipe it over with some panel wipe, just to clean out any wax or silicone residue left behind that the soapy water might not have shifted!
Anything else I could use, white spirit or similar ?
Avoid white spirit if you can as it's a spirit rather than a solvent. You could try some brake cleaner but any light weight solvent will work. Just test what you're using first as it may react with the paint already there!
Thanks. Only issue I have is to raise the headlamp protector about 1/2 cm.
Some bloke's done exactly the same on Facebook.......only he made a much better job of it!!!![]()
The bloke on Facebook has far too much time on his hands !
