BMS-C current draw. Single spark systems
Not open for further replies.
bighair
Bedford
Hi to all
Having an issue with my 2000 F650gs. (no software updates ever done)
Can anyone verify on this year of motorcycle if there if a current draw on the 20 amp fuse circiut after a switching the ignition off the draw I have is 0.04 of an amp.
Our 2002 F650CS (software status unknown as the bike was bought second hand) returns to zero after switching the ignition off .
Both machines are single spark systems.
Readings taken at the fuse box with the 20 amp fuse removed.
Both machines have a draw of around 4.5 to 5 amps with the ignition on.
This is causing my battery on the GS to go flat a lot quicker than the CS and may be causing my battery charger to show that the batttery has an issue.
Please note it has had 2 new batteries in the 3 years the bikes charging system is fine and is a very low mileage and very good condition. I know it does not get used a lot but this is starting to anoy me.
Using the GS-911 I have never been able to reset the adaption values. I can not say for certain and I am not saying it did cause this issue but it never used to flaten the battery , but since several failed attempts to reset adaption values
were around the same time the issues started to appear.
Anybody willing to see check their 650 single spark for a figure.
The other strange thing is using my GS-911
The Vin ID on the GS is shown as vvvvvv and the manufacturing date as 1400-01-04
The CS Vin ID is correct and the manufacturing date is 2002-03-05 which is also correct.
Note I have owned the GS from 200 miles old/3 months old.
