BMW Alarm
davidfbmw
sheffield
Can the bmw alarm be activated with GS911 or does the dealer have to activate
I’ve got the alarm off my old 1250 and want to transfer to the new one
I bought an alarm from another F800GS owner, it all works but would not code so the bike doesnt know it's there.
Only negative is I don't get the flashing led or turn signals. It deactivates from the fob and from the key, and screams if I move the bike etc
Bought mine off someone that took it off his 1200 and was told it wouldn’t work on a 1250
It worked ok on mine but needed coding so should work on the new one
Will get dealer to sort on first service
It probably was, it was Hull and met you at Donny services
Still working well pal
Yeap that was me. Pleased to hear its still good. If I remember correctly the issue was that the alarm wouldn't go off if the bike was moved and the dealer believed it was because that alarm (removed from a 2017) was not specified for the 2019 WC - different part numbers. Issue ended up being quite simple. With keyless the alarm wont activate if you are standing in the vicinity.
That’s right pal
Always works with me cos I put keys on side but they need to be quite close
I asked dealer to code but apparently it’s a different alarm on the newer 1250’s so can’t get it coded
