- Joined
- Sep 19, 2004
- Messages
- 6,529
- Reaction score
- 619
I have no idea what you are going on about ?Calm down ffs...
Just fucking calm down......I have no idea what you are going on about ?![]()
Calm down, Calm down.Just fucking calm down......![]()
IME tyre fitters always remove the weights first as a matter of course. Seems to be THE way to do it.Fit tyre. Check balance. If out remove any weights if necessary. Re balance wheel. Why would a tyre fitter be cleaning a wheel? If you want the bike washed and some deep cleaning of wheels it’s not a tyre fitters job. JJH
Nail varnish remover contains acetone, its well aggressive, man!If it’s a 1200/1250 with alloy wheels be careful if you do clean it off, I managed to remove the paint from mine with a very gentle solvent (nail varnish remover) which is usually safe on pretty much anything and too much elbow grease![]()
this ^^^^^
You're quite entitled to make you comment, and its much obliged, Enjoy your wine.Only on a BMW forum would someone ask if you'd expect a tyre fitter to remove adhesive from the magnets!!!.
They're not magnets!, & why would you expect them to remove the old residue.
It's an embarrassing question. Just clean it off yourself for goodness sake. Brake cleaner and a rag.
Sorry, but I've had a glass of wine and can't believe the question has been asked.
And you still haven’t got it all off, you must be shit at itI've been cleaning it off GS wheels since 1999 !
Just spray brake cleaner on a cloth, rub it into the glue and after a minute or so when it gets into the glue it will just wipe off. Just keep the cloth wet with brake cleaner.You're quite entitled to make you comment, and its much obliged, Enjoy your wine.
Edit - Thats a good point. Not sure why I stated magnets![]()
CheersJust spray brake cleaner on a cloth, rub it into the glue and after a minute or so when it gets into the glue it will just wipe off. Just keep the cloth wet with brake cleaner.
No, is the answer.Cheers
I think there's some confusion here. Not at any time have I asked for advice to remove the glue.
The question was. - "Should the Tyre fitter remove the old glue"
Hope that helps![]()
So it seems.No, is the answer.
I don’t agree with your anoligy if you can clean the wheels with a quick wipe as you would for a bit of oil fair play to you. We both know there’s a bit more involved than that. Senile? Maybe. Not stupid though. JJHwho said anything about cleaning the bike ? Or cleaning anything ?
Think you're got your wires crossed, either that or a bit senile ?
When the Oil filter is changed, And oil has drained down the side of the engine casing, Would it not be normal, and expected to clean it all off after the work is completed ? Or should the technician leave it as it’s not his job to clean it ?
So it seems.![]()
I wouldn't expect the whole wheel cleaned. Just the residue glue left over from the removed weight (Not magnetI don’t agree with your anoligy if you can clean the wheels with a quick wipe as you would for a bit of oil fair play to you. We both know there’s a bit more involved than that. Senile? Maybe. Not stupid though. JJH
Yes that’s correct. But IF the wheel is actually still in balance or needs an extra 5 g there’s little point in pulling them off only to replace them. The old weights that clipped on would be removed as a matter of course. Mostly car wheels. Fitted a few tyres in my time. JJHIME tyre fitters always remove the weights first as a matter of course. Seems to be THE way to do it.
It would actually be easier to clean the whole wheel and leave the residue!!! JJHI wouldn't expect the whole wheel cleaned. Just the residue glue left over from the removed weight (Not magnet)
I think your expectation & reality are worlds apartMixed response.
I've just got back from a 5000K mile jaunt around Europe. Italy, Sicily, Back to Italy, Boat to Croatia, Serbia, Hungary, Slovakia....... Ect ect and now need a new rear, As Im cleaning the bike, It does piss me off, that the rim has several old adhesive marks. As mentioned above, A premium company I would expect them to remove any old adhesive. We pay enough for the service. The argument about "They may damage the rim" is Fubar, as that can be applied to any work they do on the bike.
I buy my bikes outright. Never PCP. I do accept PCP bikes wont get that.
And yes, The adhesive does come off with a bit of elbow grease.
Just thought Id ask the forum what they'd expect ?
Cheers![]()
