Last time the symptoms were warming light on no ABS (tested by being able to lock the back wheel) and no speedo to start with but then working after a few miles - That was fixed by a new sensor in the rear hub.
This time I’m pulling away from some lights and the traction control kicks in ( bit of a nuisance as I was doing one of those quick starts from the wrong lane and needed to cut across everyone) anyway I’m thinking what was that all about it was a prompt getaway but nothing that should have induced the traction control when I notice the brake fail light and traction control triangle lights.
The speedo was working, so I stopped and restarted and this time no triangle but the brake fail light is still on. I’ve also no abs and the speedo is working.
Just wheeled out the garage to check again and it’s a warning light, no abs and the speedo is working so I’m thinking this is not like before.
Any pointers
2013 Hexhead GSA one of the very last ones
Wreford
Any pointers
Wreford
