Vac pump
Very good ....usually...for extracting brake fluid and air bubbles when bleeding brake systems. Its a reversal of the old squeeze the lever/pump the pedal method, instead you suck the fluid out through the bleed nipple and don't create extra air in the system by operating the master cylinder.
After you have bled the brakes, if possible put some strong elastic bands or inner tube pieces around the brake lever to leave the lever applied (under pressure) over night. This normally causes microscopic air bubbles to surface in the resevoir, thus improving further the feel of the brake lever.
The kit can also be used for levelling fork oil, engine oil and transmission oil top up corrections. Useful to for checking testing most other things operated by vacuum. Used in the car trade quite extensively, issued as factory must have kit by some.
