st247
Newbie here, gonna jump in. The confusion comes when people say clutch and mean the clutch lever. Engaging the clutch lever ( pulling it in ) disengages the clutch. Disengaging the clutch lever ( letting it out )engages the clutch. All the technical manuals i've seen mean the actual clutch pressure plate and friction plate assembly when they use the term "clutch".
So BM are asking us to pull the lever in disengaging the clutch as soon as we start an emergency stop. This has a couple of consequences that people may not be aware of.
Whipping the clutch in as soon as you start braking is the most common cause of stalling the engine( from what i've seen ). Which may lead to a loss of control and it certainly limits your options if an escape route opens up!
Leaving the clutch engaged (lever out) untill your down to the last few mph has the effect of stabilising the bike, the rear wheel effectivley acts like an anchor pulling the bike back. This keep the engine turning ( giving you the escape option ) and prevents the back wheel from leaping about going over some of the minor imperfections we have on our roads.
Personally i cant see any advantage to disengaging the clutch as i start to brake. But the reality of it, is that in the case of an emergency stop the vast majority of us will just grab the brakes. Hence why we bought ABS equipped bikes.
